Monroe Sensi Trac Shocks
Old Aug 21, 2005 | 02:53 AM
razorbak's Avatar
Default Monroe Sensi Trac Shocks
I polled the forum to see how these perform prior to buying, but nobody had tried them yet, or didn't respond to my post. I put them on yesterday, and here is my impression. (I had Bilsteins on my last discovery to compare)
These cost $33 per shock at Checker or Advance, etc. On the street, they are pretty comfortable, a little more stiff than the factory shocks, but much better cornering and handling. I think the Bilsteins repsond better on the street, but not enough to warrant twice the price.
As for off-road use, I can't remember how heavy duty the Bilsteins were, but the Monroes are a smaller piston than the stockers.
All in all, I'm very happy with the quality of ride on the street, and glad I saved the money.
Old Aug 21, 2005 | 11:07 AM
duboff's Avatar
Default RE: Monroe Sensi Trac Shocks
thanks for the info. I am going to be replacing mine soon and will keep it in mind. gotta love a rover. duboff.
Old Dec 9, 2005 | 07:10 PM
Charlie L's Avatar
Default RE: Monroe Sensi / KYB GR2 Shocks - Lots of Play?
Hi everyone
Anyone tried the KYB-GR2 on a 99 Disco II? Also I know this is a stupid question coming from "oh not so technical", but I checked the instructions and it mentions pumping the pistons as the nitrogen seems to settle. However after pumping there is quite a bit of play here? Is this normal? Should it be be movable with simply pushing down so easily. I am having a mechanic install them though.
Your truly, shock absorber illiterate
CL
Old Feb 15, 2006 | 11:57 PM
ctcnewton's Avatar
4th Gear
Hello,
New Member and new owner of Disco II 99. My disco seems to really hit hard in dips just on the road and sways pretty good around corners almost a bouncing motion. I am not sure if it needs new shocks but I figured I would replace them pretty soon. The shocks on it know look like orginals and it has 87000 on it. I guess my main question was, do you notice the bobbing around corners or large clunks going through dips, and yes this is at slow speeds. Second, How long did it take you to install the new shocks. Finally, thanks for the info on the Monroe shocks.
[IMG]local://upfiles/2221/08CDAEDD25A04DA3937D25717EBA9A91.jpg[/IMG]
Old Feb 16, 2006 | 05:49 PM
disco12's Avatar
that's a very nice looking disco.[sm=icon_rock.gif]
Jake1996D1
Dec 18, 2012 04:21 PM
dvot
Aug 10, 2010 01:23 AM
LuvToDisco
Sep 23, 2009 04:53 PM
trini defender
Defender
Dec 6, 2006 11:58 PM
razorbak
Aug 6, 2005 04:11 AM
