more 12volt outputs...
Old Nov 18, 2008 | 09:02 PM
apcollin's Avatar
Default more 12volt outputs...
Spike pointed out in response to another of my posts that running many things of one 12v plug will cause the fuse to blow.
i was wondering if anyone knew how to create a setup so you could have multiple 12v outputs?
could it be done by tracing the wire for the cig lighter back, and splicing a few more wires out? or something like that...
Old Nov 18, 2008 | 09:30 PM
Willie 00D2's Avatar
Default RE: more 12volt outputs...
You could hook it directly to the battery with a inline fuse. Use some heavy gauge wire so you don't fry it.
Willie
Old Nov 18, 2008 | 09:32 PM
There are two ways to do it, you can tap into the fuse block, find a open port, if there isint a open one then use a higher amp one, like a 30 amp.
The other way is to wire directly to the battery putting a inline fuse on the wire. That is the route that I would go.
Old Nov 19, 2008 | 08:04 AM
discoxd's Avatar
go to a car audion store, you should be able to get a multi port fuse block, like a small distribution block 1 wire in, 4 wires out, maybe more if you need it... then all you have to do is run one wire into your truck somewhere, mount the block, run your "output wires" to wherever you will need your power outlets and your all set... put the fuse block somewhere dry and easily accesible so if you blow a fuse...
________
JACKINIZE
Old Nov 19, 2008 | 09:34 AM
apcollin's Avatar
nice, good idea.
but does that mean these devices would be pulling power off the battery the entire time? Or would the electrical flow stop when the car was shut off if one of those multi-fuse ports were used.
Old Nov 19, 2008 | 09:40 AM
discoxd's Avatar
you could run a switch, manual or ignition, or you could just have them steady on... you could have accesories plugged in with constant power and as long as none of them are on then it shouldnt draw any current... much like how some cars cigg lighter outlets work with the ignition off and no key, and some have to have the ignition on...
________
WEB SHOWS
Bryan H
Feb 12, 2009 10:59 PM
kumbhani123
Apr 25, 2005 12:44 PM
drfeldman
Apr 7, 2005 03:18 PM
Yetielliott
Apr 6, 2005 12:49 AM
voelks
Dec 18, 2004 05:05 AM
