More 134a?
weight is the operative word. Commercial techs have scales they use with the larger containers, so they can see that they added an exact weight. While that is not needed with Rover, as two 340 gram (12 ounce) cans are within the spec of 700 plus/minus 25 grams. A little must be allowed for loss in the lines. Don't turn cans upside down to squirt liquid in there, the compressor won't like it. You can make things go a little quicker by placing the can in a pan of warm water.
I was going by the instructions with the gauge. Essentially you point an arrow at the ambient temperature and then the minimum and maximum ranges (in my case, due to outside temp) show 45-55. Not very scientific.
One more item worth mentioning. Did you charge the system under vacuum? You're sure you didn't break the vacuum prior to adding the refrigerant?
High low side readings indicates non-condensables are present in the system. Replace the dryer as mentioned above, pull another vacuum (run the vacuum pump for at least half an hour to be sure the system is completely evacuated), recharge the system w/ the proper weight of 134a.
So what I am hearing is that I should start over. Replace the drier, replace the oil, pull a vacuum, and charge with 134a, approximately 2 bottles (12 oz. bottles). Is that the consensus?
Of course I won't lie, I did recharge my A/C in the disco with a quick charge single gauge thing I got at Wal-mart, when driving across the middle of nowhere Oklahoma, and my choice was sweat to death or do it halfway. I chose halfway.
It's not a money saver. I just like to figure things out myself (with the forum's help). For all of the mistakes I've made I'm sure I would have saved money using a pro. Also, I like the tools.
