More 134a?
Old Jun 10, 2013 | 07:22 AM
weight is the operative word. Commercial techs have scales they use with the larger containers, so they can see that they added an exact weight. While that is not needed with Rover, as two 340 gram (12 ounce) cans are within the spec of 700 plus/minus 25 grams. A little must be allowed for loss in the lines. Don't turn cans upside down to squirt liquid in there, the compressor won't like it. You can make things go a little quicker by placing the can in a pan of warm water.
Old Jun 11, 2013 | 07:34 AM
Charlie_V's Avatar
No, the full portion for a front air only is 700 grams, a 12 ounce can is 340 grams, and you loose about 30 grams in the charging hoses per meter.
Which instructions say 45 - 55?
I was going by the instructions with the gauge. Essentially you point an arrow at the ambient temperature and then the minimum and maximum ranges (in my case, due to outside temp) show 45-55. Not very scientific.
Old Jun 11, 2013 | 07:35 AM
Charlie_V's Avatar
That pan of warm water idea is great. I deduced that it was taking longer and longer for the pressure in the can to build up as the can got cold and it got closer to empty so I set it in the air flow from the fan behind my radiator (to the side); which seemed to help it recharge for another squirt faster.
Old Jun 11, 2013 | 07:38 AM
Charlie_V's Avatar
Originally Posted by coors
One more item worth mentioning. Did you charge the system under vacuum? You're sure you didn't break the vacuum prior to adding the refrigerant?
High low side readings indicates non-condensables are present in the system. Replace the dryer as mentioned above, pull another vacuum (run the vacuum pump for at least half an hour to be sure the system is completely evacuated), recharge the system w/ the proper weight of 134a.
No, I did not charge under vacuum; I removed it prior to charging. No bueno.
So what I am hearing is that I should start over. Replace the drier, replace the oil, pull a vacuum, and charge with 134a, approximately 2 bottles (12 oz. bottles). Is that the consensus?
Old Jun 11, 2013 | 07:47 AM
"yup"!!
Old Jun 11, 2013 | 07:48 AM
drowssap's Avatar
there is your problem, why would you dump the vacuum. you have to charge the system while its in a vacuum. just bring it to someone and spend the $100 and have it done right.
Old Jun 11, 2013 | 08:28 AM
jafir's Avatar
This is the best plan, especially if you don't have a GOOD vacuum pump, and a set of manifold gauges that will read both the high and low side of the system. There is a lot more information you can get if you can see both pressures.
Of course I won't lie, I did recharge my A/C in the disco with a quick charge single gauge thing I got at Wal-mart, when driving across the middle of nowhere Oklahoma, and my choice was sweat to death or do it halfway. I chose halfway.
Old Jun 13, 2013 | 10:43 AM
Charlie_V's Avatar
It's not a money saver. I just like to figure things out myself (with the forum's help). For all of the mistakes I've made I'm sure I would have saved money using a pro. Also, I like the tools.
Old Jun 13, 2013 | 10:45 AM
Charlie_V's Avatar
Originally Posted by Disco Mike
"yup"!!
Done. It's at 35 degrees on LO/max fan at idle. Freeze a brass monkey on the highway. Thanks for all of the guidance, people!
Old Jun 13, 2013 | 10:49 AM
If you are above 80 degrees out side, you pressure should run to about 45 on the gauge, 35 is when it is 65 to 70 degrees out.
