More Coolant leaking!
Old Dec 15, 2008 | 10:29 AM
JC316's Avatar
Default More Coolant leaking!
I took my car out for a short drive early this morning... It's 6 degrees here btw! Freezing! But, at about 0830 I noticed that there was a small puddle of liquids underneath my landy. It turned out to be coolant. I looked under the hood and found that the coolant was leaking from the right side of the vehicle. From what I can tell it looks like the leak is coming from just over the valve cover. I traced a tube from the coolant tank over to the valve cover area. I felt for cracks but couldnt find any. I drove the landy over to work about a hour and a half ago and checked under the car for leaks again and there wasnt any.... On the way to work I noticed that there was a high pitched whirring sound every time I accelerated. That sound is also gone.... Any ideas on what my problem might be?!?! I used 50/50 dexcool that they sold at Autozone!
Thanks in advance for the help
JC
Old Dec 15, 2008 | 01:00 PM
Default RE: More Coolant leaking!
Drivers side valve cover? Leaking ontop of the valve cover then running down onto the ground?
http://www.roverparts.com/Parts/ERR6623.cfm
or
http://www.roverparts.com/Parts/MGM000010KG.cfm
Go with the first one, you can buy it at your dealer for like $5.
Old Dec 15, 2008 | 02:15 PM
Following up on Spikes, I would go with the second link, you will most likely need the full gasket set that Rover updated 4 plus years ago to stop this leak.
Old Dec 17, 2008 | 01:05 PM
JC316's Avatar
The leak appears to have been a one time deal. It hasn't leaked since. Is this normal? Still think I should do a replacement?
Old Dec 17, 2008 | 01:31 PM
redhotbuzz's Avatar
ten bucks doit.. From what Ive learned about Rovers theres no such thing as a One Time Deal unless you do it yourself..If you dont take care of it theres a big one comin round the mountain
Old Dec 17, 2008 | 01:52 PM
Either replace the whole kit, the proper repair, or by-pass the system by joing the two hoses together, which I did 4 or 5 years ago.
Old Dec 17, 2008 | 03:24 PM
jycsalas's Avatar
So I can join the two hoses together and cap off the ends of the heater plate and thats it?? i live in the Caribbean so my throttle body doesn't need heating up!!
Old Dec 17, 2008 | 05:53 PM
I live in Colorado and it doesn't seem to cause me problems on these -10 to -20 degree mornings.
Old Dec 19, 2008 | 12:47 AM
phatduc's Avatar
ORIGINAL: Disco Mike
problem solved!! I like dat! So you by passed both heaters? No issues in the winter?
________
GALCO TUCK N GO HOLSTER SIG SAUER RIGHT HAND
Old Dec 19, 2008 | 12:51 AM
phatduc's Avatar
done deal... I'm in MT, plenty of 20 below mornings, but a knowledgeable wrench and stocked parts are farther afield than in CO. I'll try it though!!
________
Extreme Vaporizer
rally1
Feb 22, 2022 06:22 AM
green_
Nov 25, 2013 04:44 PM
BrokeRover
Feb 22, 2012 06:13 AM
Bryan H
Feb 12, 2009 10:59 PM
