More Cooling Questions (bad t-stat)
Old Jan 26, 2009 | 01:53 PM
Jawbox's Avatar
Default RE: More Cooling Questions (bad t-stat)
No worries Mike, like I mentioned I already ordered the new assembly, is just won't be here until the end of the work. The emergency fix is just that, for an emergency like facing certain death without a trip to the hospital.
Old Jan 26, 2009 | 04:11 PM
mwindth's Avatar
ORIGINAL: Disco Mike
Do you have a death wish for your engine???????????????????
Your upper radiator hose was discontinued over 4 years ago because of it's high failure rate.
Buy the new style hose with the up-dated "T" and bleed screw.
Disco Mike,
Mine is a 2001 and has the "T" with a bleed screw...does this mean my upper radiator hose had been replaced within the past four years? I am the third owner and do not have the service history.
Thanks!
Old Feb 7, 2009 | 03:38 PM
Jawbox's Avatar
Well, the upper hose came in last week, and I'm still leaking like crazy. Everything points to the water pump, which I didn't have any luck getting off before. Today, I picked up the correct fan clutch tool, removed the fan, and things are looking much better. All the other hoses are looking good, so I think once I get the pump in, I'll be back in business.
I've gotta admit, two weeks without the Discovery, I'm starting to get cravings...
Old Feb 8, 2009 | 08:41 AM
ORIGINAL: mwindth
Disco Mike,
Thanks!
Yes, you have the correct hose.
mmb
Dec 1, 2014 11:11 PM
kwallace
Nov 21, 2014 03:46 PM
binvanna
Feb 17, 2014 06:08 AM
tigertrakstar1
Jun 24, 2010 10:48 AM
Bryan H
Feb 12, 2009 10:59 PM
