Mount for CB Antenna
RE: Mount for CB Antenna
I just purchased (and in the middle of installing) my cb and antenna. You may want to consider the NGP (No Ground Plane) antenna Firestik has if you go with the spare tire mount. All the mounts I've seen used bolts to attach to the carrier. Firestik's site is a little confusing. In the tech section they reference EE's Disco antenna installation, but the write-up fails to mention anything about connecting a ground. Be sure to read over the tech section Firestik has and then make your decision on the antenna.
