mpg drop
Old Jun 4, 2014 | 02:27 PM
ninjaff21's Avatar
ok I'm waiting on the parts to arrive to my auto zone its the same ones that AB sell so thats good i guess from the looks of it i don't need to get under the car do i?
Old Jun 4, 2014 | 02:44 PM
drowssap's Avatar
oh you will be getting under the truck
Old Jun 4, 2014 | 02:49 PM
jwigum's Avatar
To change the O2 sensors? Yeah, you'll need to get underneath for the rear. I have to do my passenger side O2 sensors, but I'm going to try and do the pre-cat one from the top.
Screw the designer who thought it was a good plan to put the connector behind the engine... Just saying.
Old Jun 4, 2014 | 03:32 PM
jamestfl's Avatar
the front ones can be got from the top only, with lots of extensions. and make sure you get/rent an O2 sensor socket- AZ is sure to have one.
Old Jun 4, 2014 | 03:34 PM
ninjaff21's Avatar
i have a open end wrench will that not work?
Old Jun 4, 2014 | 03:56 PM
ninjaff21's Avatar
I'm only doing the fronts I've been trying for an hour with an open end wrench a 7/8 and a 15/16 neither are able to get a good bite for me to whack it with a hammer and even try to get it off. I've used a lot of wd40 and its just not working. also for when i get to it how do i remove the clip thats covered in oil for the harness i tried to do that a while ago and couldn't get it off.
Old Jun 4, 2014 | 04:35 PM
dusty1's Avatar
22mm fits too
Old Jun 4, 2014 | 04:36 PM
ninjaff21's Avatar
okay ill keep trying its just such an awkward angle on the passenger side and its not wanting to get a grip
dusty1's Avatar
Squeeze orange or gray clips on plug to release
Old Jun 4, 2014 | 04:55 PM
dusty1's Avatar
Heat helps
