MR
Old Jan 12, 2017 | 12:45 PM
Newby Taylor's Avatar
7th Gear
Default MR
Hi all, does any body know the weight of a 99 disco 2 v8 for bonnet struts and bonnet position thank you in advance
Old Jan 12, 2017 | 01:27 PM
abran's Avatar
search AlexM he did a write up on bonnet struts.
Old Jan 12, 2017 | 01:34 PM
mollusc's Avatar
https://landroverforums.com/forum/di...forever-74885/
Old Jan 12, 2017 | 01:50 PM
JUKE179r's Avatar
I'm going with AlexM's suggestion of the 60lbs gas props but install 2 of them.
I totalled up the cost and it'll be about $30 for the gas prop and 4x 10mm ball brackets/mounts.
Old Jan 12, 2017 | 02:16 PM
mollusc's Avatar
If you read through the thread, the OP says in post #56, "If you're going double, definitely don't double up on 60s."
Recommendations for doubling are to use 2x30 or 2x40.
