mud?
The pressure washer may strip paint off of a re-spray, so if you have had body panels repainted be careful not to get the nozzle too close or the jet can get up under a stone chip or nick and start taking the paint off in sheets.
And again, matter of opinion I'm sure, but a new Rover does not like water - too many electronics. Old diesel Rovers could run under water without a problem, but if you see a snorkel on a D2 it is for show only - the recommended max fording depth for a D2 is 20 inches FOR A REASON. A D1 might have a little more water tolerance, but then you get to deal with the other voluminous Lucas shortcomings. Pressure washers are great tools, but they can tear stuff up in a hurry - rubber, plastic, paint - caution is advised.
If you want to spray the insides of your fenders fine, but not the underbody.
And also note that mud will stick to a rough surface better than a smooth one.
https://landroverforums.com/forum/sh...er+Wash+engine
BUT i agree 100% with taking caution. Get to close to a rubber hose and you'll knock it right off. And something I have forgot to mention, make sure you do it while the engine is cool.
The Mud will draw out natural oils in the paint and fade it fast. Actually, the opposite of what Spike told you will happen. If you bake mud on a truck, it will oxidize fast.
Do not use any chemical degreasers on the engine. They will eat the seals on an engine that is already prone to leaking. Use water only. On a D2, you will be ok to pressure wash. If you are worried about electrics, stay away from the ECU and the coil pack.
I would only use undercoating on the underside of the truck. Bed liners can crack and if they get water trapped in them, they will just rust out what they are coating. Use 3M undercoating every 6 months if it is getting worn off from road debris. Truck liner is not a good idea.
I don't have any "good" tools any more - they were all "borrowed...."
Landrovers have a built in "Anti Corrosion" system, they leak a bunch of oil thereby oiling the undercarriage and inhibiting any rust.
Another thing about mud, especially on an off road trail. It will contain all the gas, oil, brake fluid, etc from every truck before you that had any leaks or breakdowns. You REALLY want to get it off your paint as soon as you can, I know it looks cool, but if you leave it on too long, it could be bad
