Muffler Front Flange Studs
Old 01-27-2020, 07:35 AM
Kevinbly's Avatar
Default Muffler Front Flange Studs
Hi guys,
While removing the main mid muffler/silencer, the studs on the front flange (flange with the 2 bolts without gasket) sheared off. Does anyone know how the studs are fitted into the flange? Are they threaded or welded in place?
I want to remove the studs and replace with bolts but want to know the best way of removing the old studs. I am hoping that I can get around drilling them out , especially since it seems the flange cannot be removed from the y pipe to do it...
Any suggestions?
Thanks for your help.
Kevin B
2004 DII
Old 01-27-2020, 08:05 AM
WaltNYC's Avatar
Mine were welded in. I spent some quality time under the truck drilling them out. Pain in the ***.
You could always drop the entire Y pipe but that also can be a pain.
Old 01-27-2020, 08:07 AM
XRAD's Avatar
got a buddy with a torch? Save a ton of time. cut out old studs and use through bolts?
Old 01-27-2020, 08:50 AM
Kevinbly's Avatar
Thanks for the replies guys. Do you think I might be able to simply grind the head off the stud and knock it through? Or will drilling be a must?
Old 01-27-2020, 09:19 AM
Sixpack577's Avatar
They are studs, and they are in there good.
Takes Alot of effort to get them out, and they are hardened and like to eat drill bits.
Use fire.
I swapped mine for bolts, and it was a pain.
Old 01-27-2020, 09:25 AM
0304Disco's Avatar
Depending on the condition of your flange, I found it easier to cut the flange off and install a split flange purchased off amazon. My bolts were a mess since I live in Chicago.
The following 2 users liked this post by 0304Disco:
cvhyatt (01-28-2020), Sixpack577 (01-27-2020)
Old 01-27-2020, 09:46 AM
Sixpack577's Avatar
I also ended up cutting off the old one and replacing the clamp over the flange.
Much quicker and easier.
Old 01-27-2020, 09:50 AM
Kevinbly's Avatar
Split flange? This sounds like a great option. I saw a post recently where someone said the holes didn’t align with the split flange. Can anyone provide a link for a flange that worked for them?
Old 01-27-2020, 09:51 AM
Friday Night Disco's Avatar
I drilled the stud heads off and used a mallet to whack the threaded side until they popped out. Would be easier to drop the Y pipe as any whacking could mess up the manifold to Y studs/ gaskets. I then replaced the studs with some zinc bolts and nuts so I didn't have to worry about rust again. My only issue was that I over tightened the new bolts and had to back them off a little bit.
Old 01-27-2020, 11:17 AM
0304Disco's Avatar
Here you go on the split flange. It works!!2.5" 2-1/2" inch Exhaust Flange...
Amazon Amazon
Quick Reply: Muffler Front Flange Studs
