Multi plug fix
Old Aug 7, 2020 | 10:46 AM
JoeLena's Avatar
Default Multi plug fix
UG showed a code for the passenger side knock sensor so I went to have a look and found both wires off at the plug.
Wanted to check on ideas on fixing. Can it even be repaired since no wire is even sticking out to splice? How are those wired in the first place? If a new plug is sourced is it something DIY? I have an automotive electric shop close and will check but looking to see what the community thinks.
Old Aug 7, 2020 | 10:47 AM
JoeLena's Avatar
Old Aug 7, 2020 | 05:47 PM
rhyslegge's Avatar
Its a common issue with automotive and aircraft connectors. The little metal pins are crimped onto the wire, and the pin has a securing device on it. The pin is then pushed into the plastic plug and it locks in place. There are extractor tools available, the pins are most likely still in the plug. But if you have an electrical shop nearby then they should be able to fix this very quickly with a new set of pins. The plastic connector should be salvageable.
Rhys Legge
Old Aug 7, 2020 | 07:21 PM
JoeLena's Avatar
Thanks for that info, will see what the shop can do.
Old Aug 11, 2020 | 04:00 PM
JoeLena's Avatar
So the local auto electrical guy couldn't get the plug apart and I am having trouble sourcing one, no local donor trucks close. Having trouble finding the part number I need. I did post in the classifieds for one but if someone else has an idea let me know please.
Betty4banger
Nov 30, 2018 01:01 PM
eli93245
Jun 7, 2017 01:41 PM
DAMINK
Aug 18, 2015 04:09 PM
bootzilla
Oct 11, 2012 01:13 PM
smokey73
Feb 24, 2010 05:15 PM
