Multi Warning Lights on 2000 D2
Old Apr 16, 2012 | 10:35 PM
deltaridge1's Avatar
Angry Multi Warning Lights on 2000 D2
All of a sudden I have three warning lights pop up on the cluster. Oh yea on a 2000 Disco 2
ABS light, a TC light and what look slike a truck headed downhill with a "!" behind it.
Truck roll fine and shifts just fine... Even stops smoothly... I am open to suggestions, a cure would be better!
So any assistance would be helpful. I am 1,700 miles from my Disco tech
Old Apr 16, 2012 | 10:42 PM
search forum for three amigos
Old Apr 17, 2012 | 07:21 AM
Discovery SE7's Avatar
I would think a damaged ABS sensor could do all of that. I'll look up the three amigos thing and see what others have said. I Know ABS and traction control can be caused by that, but the hill descent, not so sure of.
Old Apr 17, 2012 | 08:39 AM
There are 16 reasons for the 3 amigos to come on and your best bet is to have a "GOOD" Rover mechanic with an ABS scanner read the codes, give you an estimate and get back to us before you OK any work.
Old Apr 18, 2012 | 12:22 AM
Thanks for the past comments! I truly appreciate any and all suggestions. My problem is that I have recently moved to Yuma, AZ. I have only seen less than a handful of RR and LR's floating around this area. Got a lot of foreign mech's around here... Scared to do the shotgun method of locating a someone that understands the working of a LR. Sure do not need someone expermenting to fix my 2000. I would rather have a personal reference.
I have seen someone that sells a ABS scan tool.. A little pricey... But I might not have a choice to chase off the amigo's.
"By chance, does anyone know of a LR tech in the Southwest" I just got word of one in Mexican border town... now that is a scary thought to consider....
Old Apr 18, 2012 | 06:12 AM
ebg18t's Avatar
You can rent the abs tool. There is a Guy in the classifieds that does that.
Old Apr 21, 2012 | 08:21 AM
Thanks... I will look and see
cipher982
Nov 9, 2019 11:22 AM
freelandman
Freelander
Feb 16, 2009 10:22 PM
denis06
Mar 3, 2008 03:09 PM
dow
Aug 23, 2007 11:07 PM
