multiple atempts before starting
Old Apr 19, 2008 | 09:34 AM
DiscoOn22s's Avatar
Default RE: multiple atempts before starting
hey mike fuel filter on 2002 disco is underneath the right passenger seat of course underneath the disco but in relation to that area right? i got under there this mornin and i think i saw it there. im going to try that next to see if it fixes my starting problem.
Old Apr 19, 2008 | 09:38 AM
ORIGINAL: DiscoOn22s
DII's dont have a servicable fuel filter. It is inside the fuel tank and is only replaced when you replace the fuel pump.
Old Apr 19, 2008 | 09:47 AM
DiscoOn22s's Avatar
oh ok thanks spike
Old Apr 19, 2008 | 11:03 AM
Not sure what you saw, but as Spike has mentioned, D2's don't have a external fuel filter.
Old Apr 20, 2008 | 08:55 AM
DiscoOn22s's Avatar
so how can i check to see if i have good fuel pressure during starts?
Old Apr 20, 2008 | 09:02 AM
We have already said how to check it. Turn on the key, then on the engine is a schrader valve, looks like a tire valve, remove the cap and press on it, if fuel shoots across the room, your good if it dribbles, your no good.
Old Apr 20, 2008 | 09:09 AM
DiscoOn22s's Avatar
LoL where is that valve on the engine? should i wear some sun glasses?
Old Apr 20, 2008 | 09:33 AM
Yes, googles, it is on the fuel rail, not sure where on ther Bosch engine but on the right side of the GEMS engine. You have the Bosch engine.
Old Apr 20, 2008 | 09:36 AM
Have you done what I suggested yet, if not go do it and then get back to us.
As for the location of the valve, forget it, on a D2 it is nearly impossible to get to it.
Old Apr 20, 2008 | 06:05 PM
DiscoOn22s's Avatar
OK MIKE I DID THE KEY TURNS PROCEDURE AND IT SEEMS TO HAVE WORKED. SO WHAT DOES IT MEAN AGAIN?
