MUltiple Codes/ P0455. PO441.P1300.P0306.PO300.PO301
Old Jul 25, 2019 | 10:57 PM
Jeff NYC's Avatar
Default MUltiple Codes/ P0455. PO441.P1300.P0306.PO300.PO301
Hello All,
Rover running rough for couple of months with no codes. Replaced plugs with Champion double platinum. A little better. Then the 3 amigos and M 7S lights. Replaced rotors and pads. all good. The the PO4455 gas cap crap. Strong gas smell in hot weather. Replaced purge valve and erased code. 300 miles later all ofthe above codes. Running 93 octane and no coolant loss. Will try brake cleaner on all vacuum hoses and mist wires at night for spark and add sea foam but ..Am I wishing?
Replaced O2 sensors 2 years ago when thieves stole my catalytic converters. Is it the coils and wires? can it be anything else. They are original.
There are no coil relocation kits around and the fix in New York is $900 smackeroos.
Please advise.
Thank you,
Jeff
2003 Disco 2 with secondary air. 265/70/16 and ARB bumper, Hella fogs. Blue 134.000 miles. Head gasket replaced at $70k miles
Old Jul 25, 2019 | 11:19 PM
jkid's Avatar
All original? Jeez replace those wires with some good ones, that’s where my money is. With the right hands you can do it without pulling the intake but pulling the upper intake off is no biggie
Old Jul 25, 2019 | 11:25 PM
jkid's Avatar
Cylinder 1 and 6 are on the same coil so maybe it’s that but 130k on the original wires is a lot.
Old Jul 28, 2019 | 09:21 AM
Jeff NYC's Avatar
Thank you guys. I planned on replacing wires and since I'm removing plenum might as well do coils. However the evap codes 0441 suggest a vacuum leak or bad charcoal canister, purge valve issues could be causing the misfires. Is this a possibility? I plan to pick up a vacuum gauge and or blow smoke into a hose.
Old Jul 28, 2019 | 11:18 AM
Jason Feuerstein's Avatar
It would be odd for a purge valve problem to be causing misfires in only two cylinders. I would say it's more likely you have multiple overlapping issues.
cta
Jul 14, 2016 11:15 AM
mike111
Jan 13, 2014 06:48 PM
DooDer
Jun 20, 2012 03:24 PM
hhalimi
Mar 12, 2012 10:17 PM
