Multiple problems - are they conected
Old Jun 18, 2009 | 07:13 PM
DanR's Avatar
Default Multiple problems - are they conected
So the car is a 2004 with 47k on the clock. It has ran faultless for the last 4 months and 6k miles until last week.
First the oil light came on at low RPM.
then 4 days later the service light came on flashing
then after 10 miles trying to get home the car started missing
I ran the codes and there are 2 P0307 cylinder 7 misfire
Could these be connected? What is my next step? (replace leads? do an oil change ?)
Old Jun 18, 2009 | 08:07 PM
First check the oil level.
What weight of motor oil are you using?
Old Jun 18, 2009 | 08:09 PM
DanR's Avatar
oil level is fine however when light came on I put in mobil 0-40w which is all they had. I know it is light but I only added 1 quart
Old Jun 18, 2009 | 08:11 PM
Ok but what is in it right now? What weight is the other 5 quarts?
You are going to need to get the oil pressure tested before you do anything else.
If the oil light comes on again do not drive the truck as you will blow up the engine.
Old Jun 18, 2009 | 08:28 PM
DanR's Avatar
rest of oil is 15-50w. The light only comes on when at idle and instantly goes away with revs
Old Jun 18, 2009 | 08:32 PM
Ok, you need to have the oil pressure tested, cold at idle, cold at 2,000 rpm, hot at idle and hot at 2,000 rpm.
The mis fires are not related to the oil light, the oil light is your #1 priority, your oil pump may be failing.
I asked about the oil because if you use 0w-40, 0w-20, or any other 0w- and it is really hot out and you worked the engine hard the oil can get to thin and cause the oil light to come on.
Old Jun 18, 2009 | 08:46 PM
And deal with that #7 misfire before you burn out a Cat.
Old Jun 18, 2009 | 09:10 PM
DanR's Avatar
is the misfire likely to be leads and or plugs?
Old Jun 18, 2009 | 09:18 PM
Replace them both, bad leads will cause the plugs to foul.
Old Jun 23, 2009 | 09:12 PM
DanR's Avatar
ok an update,
oil pressure is fine
misfire is not leads or plugs and the garage reakon it is the coils. They have quoted me $1000 for 4.5 hours labour to replace the coils?
Does this sound right?
