My 04' Disco rear fog lights not coming on...
Old Nov 5, 2009 | 12:33 AM
Mtree's Avatar
Default My 04' Disco rear fog lights not coming on...
Hey Gents,
I've been searching on here for the better half of 2 hours, i'm tired!!
My rear fog lights on my 04' Disco are not coming on. The light on the switch illuminates but nothing happens. Fuses are ok. How do I remove the switch and where can i find the relays if any for them??
Thanks in advance...
A.J.
Old Nov 5, 2009 | 07:39 PM
Are your head lights on?
Your head lights must be on for the rear fogs to work.
Otherwise check your bulbs.
Old Nov 5, 2009 | 07:45 PM
Good question Spike.
Old Nov 5, 2009 | 11:29 PM
Mtree's Avatar
I've been using them alot since we've been having a lot of heavy rain in the northeast. They jusy stoppped working the other day. I stuck my hand behind the lens and wiggled the wire and it flickered.
What could that be?
Old Nov 6, 2009 | 06:33 AM
QuickSilver's Avatar
7th Gear
What could that be?
Loose wiring?
Should be an easyish fix.
Old Nov 6, 2009 | 12:39 PM
AK Rover's Avatar
The contacts inside the socket sometimes work loose so they don't make a good connection to the bulb base. Pull the bulb, bend the contacts in slightly and put a glob of dielectric grease in the socket. Since it flickers when you giggle the wire you know he bulb is good.
booper169
Mar 20, 2019 09:37 PM
Snowdog
Apr 7, 2016 01:05 PM
Frank4
Nov 21, 2015 05:47 PM
abran
Oct 1, 2013 09:09 PM
jordamf
Aug 2, 2011 09:04 AM
