my 95 disco is killing me!!!!!!!!help
Old Aug 21, 2008 | 08:35 PM
benflynn's Avatar
Default my 95 disco is killing me!!!!!!!!help
ok, i have code 44 and 45, left and right O2
95 disco 80kmiles, good amm, new ign amp, blaster coil, good 8mm wires,recent HG swapp
ok, the truck will bog out after i have been driving it for a while, it will loose power untilll i open it up 90%+ then it pulls hard, sometimes it will drop the idle and gets real unresponsive, will stall if you let it, seems to get worse w/heat soak
when it dose clear up after you floor it, it dumps unburnt fuel
seems to be worse under sustained load
i could use some help, this thing is gilling me
Old Aug 21, 2008 | 08:52 PM
Default RE: my 95 disco is killing me!!!!!!!!help
Ok man, no offense but your typing skills are hard to interpit, so I will do my best to help you.
I think that your cylinders are loading up with fuel and then you are flooding the engine. Once you floor it and clear the unburnt gas out of the engine it runs fine.
I would replace the O2 sensors, they are sending a "lean" signal to the ECU causing it to dump excessive amounts of fuel into the engine. More than it can burn.
My wifes Volvo did this same thing when the front O2 went bad. At idle the engine would load up with fuel and when you tried to give it gas to drive it would want to stall.
Old Aug 22, 2008 | 10:23 AM
okdiscoguy's Avatar
Older O2 sensors are only good for about 80K and start to go bad. It is time for you. Atlantic British has some pretty good prices for them...
Old Aug 22, 2008 | 03:00 PM
benflynn's Avatar
worth a shot, thanks for the help
Old Aug 22, 2008 | 03:30 PM
Those are the codes that you have so I am willing to bet that is the problem.
PeetzLR3
Dec 11, 2023 11:21 PM
powderhound
Jun 20, 2014 07:52 PM
DiscoIIBrandon
Mar 11, 2011 05:15 PM
SDinDS
Nov 13, 2010 01:07 PM
