My Baby is Dead
Old Feb 25, 2010 | 09:21 PM
hilltoppersx's Avatar
Originally Posted by Willie00d2
Can you have it welded? They do that to race aluminum blocks all the time, why not a Land Rover.
Willie
JB weld it! haha..
Old Feb 25, 2010 | 09:29 PM
Disco2Fever's Avatar
The only thing I regret is that I didn't have the dealer look at it BEFORE I had the head-gaskets replaced. Remember that, guys: The dealer was $75 for the first hour, and $102 for each hour after that. It took them 45 minutes to diagnose them, and it was $100 to have it towed, and $100 to tow it back.
So, for less than $300, I found out I have a busted block.
If I wouldn't have had the needless head-gaskets done, I'd have $2,000 to put toward a new block, and I could probably do it in two weeks, instead of 1.5 months.
I'm going to begin doing my research right NOW, so I can make sure that my next engine block lasts 200,000+ miles.
Old Feb 25, 2010 | 09:42 PM
WARWAGON's Avatar
Ha you can never be sure with these! Good luck with gettin it back together!
Old Feb 25, 2010 | 09:43 PM
PS- You guys know what I'm gunna do?
I'm going to take a thermostat, and smash the guts out. Then install it, and see if it'll stay cool like that. The block is cracked in such a way that NO coolant is entering the crank-case: Only the firing chamber of #7. And it's a very small amount- but there's enough to create an air-pocket.
Well, it runs fine, it just can't pressure up enough to cause the t-stat to open.
So, I'm going to pop that trucker open and see if I can limp it back and fourth to Portland to my office and back until I get the money for the block.
What's the worst thing that can happen? I cease the engine up? Who cares. I'll probably buy new pistons and a crank shaft anyway. And how much are heads? I guess I need to price this stuff out, but there's no sense in spending $4,000 on a block, and then putting crappy old parts in it.
Old Feb 25, 2010 | 09:49 PM
Do these comes with pistons and a crank?
http://www.roverparts.com/Parts/9257D.cfm
Old Feb 25, 2010 | 09:50 PM
starrock's Avatar
wouldn't just removing the thermostat altogether accomplish the same thing? or does it provide some sort of sealing in conjunction with its housing?
Old Feb 25, 2010 | 09:51 PM
Yeah, the thermostat is enclosed in a PVC y-pipe.
Old Feb 26, 2010 | 12:10 AM
Willie00d2's Avatar
Short block is the complete lower end assembly, crank,rods,pistons,cam
Willie
Old Feb 26, 2010 | 12:19 AM
Willie00d2's Avatar
Here is a 4.0 for sale.
Willie
http://cgi.ebay.com/ebaymotors/99-00...Q5fAccessories
Old Feb 26, 2010 | 06:52 AM
Thanks friend. I'm going to get one of those new ones from Atlantic British, when I do it though. They say that they have fixed the sleeve problem, and that sounds wonderful. I've always wanted to own a brand new engine, and take care of it from day one, and this is my chance.
It'll be 6 or 7 weeks before I can afford it, but if everything goes right, I should be able to do it then.
