Is my CDL and traction control working on my 2004 Disco II
Old Apr 29, 2021 | 03:19 PM
  #21
B Strife's Avatar
Still makes sense to me to try to see if it's working mechanically and then pursue the light issue.
Old Apr 29, 2021 | 03:35 PM
  #22
mollusc's Avatar
Agreed, the bulbs have probably been removed. But that's not going to help at all if your system is throwing codes.
Old Apr 29, 2021 | 04:05 PM
  #23
Richard Gallant's Avatar
@B Strife You can confirm the CDL by dropping the front driveshaft, putting in CDL and driving
ABS/Traction Control/Hill Descent are all electronic so the Lights & Codes are critical
Old Apr 29, 2021 | 04:35 PM
  #24
Speedracer93CobraR's Avatar
8th Gear
Good news, I think...
I engaged CDL and it is clearly working (at least to some degree) because when I turn sharply on asphalt; I get the shudder that occurs when you have a locked rear end. The front and rear tires are clearly trying rotate at a different speed causing a shudder. This seems like a positive.
Old Apr 29, 2021 | 10:18 PM
  #25
mollusc's Avatar
Congratulations! You've now put a large amount of strain on your transfer case.
Don't engage the CDL on a gripping surface. It's just asking for trouble.
Old Apr 30, 2021 | 07:54 AM
  #26
8th Gear
I turned left for 10 feet and right for 10 feet. If it can't handle that to check and see if it's functioning; I am not impressed.
Old May 1, 2021 | 05:51 AM
  #27
zski128's Avatar
The transfer case is very stout. As long as you are not locking it on high traction surfaces too long you’ll be fine. The most common failure is the vent tubes getting melted shut on the exhaust and over pressuring the case which starts to leak oil past the seals and running it dry. I would suggest servicing the case and making sure the oil is topped off. It did appear the TC was working in your first video just need to be a little more consistent with throttle.
Old May 1, 2021 | 09:52 PM
  #28
8th Gear
Thanks for your input. When you're sliding backwards down a hill and teetering on 3 wheels, it's tough to hold a slow and steady throttle.
Old May 2, 2021 | 01:57 AM
  #29
Getting your ABS sorted out so traction control works is very helpful
Enad
Mar 26, 2019 12:29 PM
Mr. Tick
Dec 9, 2017 11:07 PM
Fivespddisco
Jan 5, 2013 12:38 PM
5bravobravo
Jan 5, 2013 01:38 AM
catchmyktm
Jun 5, 2008 10:59 AM
