My compression test results 😔
1=180 3=150 5=140 7=170 8=30😳 6=180 4=160 2=180
Put a bit (ok too much I think) of oil in #8 to test if it was the rings. Initially it jumped to 200 and would drop back to 30 after cranking. After I got much of the oil out it would mostly go from 90 and sit at 30 after cranking. My compression gauge does have an O ring btw.
Head gasket for sure?
When I had it running it I could hear a puff or a pop from around #8.
I read somewhere that might be and indication of the cam being ground down.
IMO it could be piston rings but I would put my money on valve seating correctly. If only rings were worn and losing pressure evenly the whole test would be similar. IMO it's more likely a coked up valve or bad valve seating caused by a bent valve stem or even a loose valve seat. In any event the heads need to come off so it's worth testing the valves and new stem seals fitted.
Fit new gaskets everywhere especially head gaskets. Victor Reinz HG's are good to go.
