my disco is making me go insane!!!!
Old Mar 28, 2013 | 09:08 AM
  #21
me 2's Avatar
Default stuff
Thanks again Savannah Buzz. #2 fuse is good. I am getting downstream codes also. Im going to do a 12v test tonight to see if there is actual power going to the o2s.
Old Apr 20, 2013 | 07:59 PM
  #22
TexasDiscoII's Avatar
I'm having the same issues, did you fix yours? I have done everything you did lol even redone both front o2 wiring, No luck. Same codes come back, p1129 is this first to come back. I'm thinking there's a short somewhere just don't know where else to look maybe under the dash...
Old Apr 20, 2013 | 09:21 PM
  #23
Alan Phillips's Avatar
If you clean the connectors and made double sure the wiring is correct and ok then you could have gotten a bad O2 sensor. It happens, I have have first hand experience...
https://landroverforums.com/forum/di...sensors-53517/
Hope this helps you.
Old Apr 21, 2013 | 10:03 AM
  #24
me 2's Avatar
Update: went ahead and purchased 2 new upstream o2 sensors from advance auto and all codes went away. That was a few weeks ago and still no codes. I originally bought them from eBay.... : (. Won't do that again.
formel3
Aug 16, 2013 05:27 PM
wheelgarage
Dec 12, 2012 12:43 PM
Camdisco24
ROAMING WITH FRIENDS
Jan 3, 2010 12:10 PM
llPANCHOll
May 1, 2009 02:18 AM
sonton2003
Aug 20, 2008 12:47 AM
