My Discovery keeps overheating, What can I do?
hi,
I have a W reg Land Rover Discovery TD5 (Auto) and it keeps overheating on long (ish) journeys. It does roughly 50 miles then overheats and pours water out of the pressure cap, I have changed the pressure cap and the thermostat. I guess the water is circulating properly because i have heat inside the car when the car is revving, but when stationary for a while, it starts to blow through cold. I have also fitted a new power steering pump, but do these cars have problems with the Water Pump? the car can run for hours without the pressure cap on outside. Theres no signs of oil in the water and no smoke coming out of the exhaust. Can you help, or give me advice of what to do next?
Thanks.
Thanks.
Mc Ayoub Salim Gunners (05-25-2020)
Things that it could be, in no particular order:
1. Coolant level low. Hopefully no coolant being consumed other than overflow.
2. Radiator (and AC condenser) clogged with mud and leaves on outside.
3. Radiator clogged wth sludge on inside, flush (reverse direction), remove al traces of Dexcool coolant (turns to sludge under a wide variety of conditions). Also flush heater core both directions.
4. Won't be fan clutch - does not overheat at idle and slow traffic - but spin anyway when engine hot, and not running. A viscous clutch should not make more than one turn when released and warmed up. When cold should feel like peanut butter inside. No freewheeling allowed.
5. Maybe water pump, but should show up faster than 50 miles.
6. Belt route making pump run backwards.
7. Fan was removed and replaced in reverse direction, now pulls air away from engine, rather than toward engine.
8. Cracked engine or head or head gasket.
How long does it take at idle to loose heat?
1 minute?
15 minutes?
Diesels loose heat when idling because the run cooler than petrol engines and that is 100% normal, so is excessive smoke after idling for extended periods.
Check the drive belt tension and condition of the drive belt, if it is slipping it will not turn the water pump fast enough to cool the engine.
1 minute?
15 minutes?
I have already done a pressure test and bought a new, Genuine Land Rover pressure cap and i still have the problem. When running the engine without the viscus fan on the radiator all the hoses, bar the two bottom ones on the rad, both going to the fuel cooler, which stay cold, could the fuel cooler be blocked?
1 minute?
15 minutes?
1 minute?
15 minutes?
