Is it my head gasket?
Old Jan 27, 2018 | 06:46 PM
fgd's Avatar
fgd
Default Is it my head gasket?
Recently I've been going through some coolant and I thought I had traced to my throttle body heater. That leak has slowed to almost nothing, but I'm still losing coolant. I also noticed some white smoke in the exhaust at start up. I also had a cylinder #2 misfire the other day under heavy load (punching the gas to get out of the way of a semi). The misfire might be unrelated.
So I rented a coolant system pressure tester from the local parts store. Lost psi pretty quickly over a 20 minute period. No noticeable coolant leaks that I saw. I didn't think to look at the back of the engine at the time. I thought of that after reading numerous HG threads today. And looking now there is definitely something leaking back there on the passenger side. See attached photo - and sorry for the blurriness. Hard to get the right focus in the engine bay. There's no over heating. Ultra gauge shows temps about 190-194 consistently. That's with the 180* thermostat.
From what I've read this sounds like coolant getting into a cylinder. How do check that? Pull the spark plugs and inspect? Other tests I should do?
I'm especially bummed about this because the previous owner had installed a fully rebuilt 4.6 in the rig. It has about 14,000 miles on the rebuild. Head gaskets should last longer than that.
Thanks in advance for any input.
Old Jan 28, 2018 | 08:17 PM
Randy Murzyn's Avatar
I hate to say it. But, you probably have a cracked block behind a cylinder sleeve. Double check the back of your block towards the fire wall. Typical for a hg to leak in this area.
Old Feb 9, 2018 | 03:04 PM
fgd's Avatar
fgd
Had it in to the shop. There was a sneaky leak on the throttle body heater so I had them do the bypass.
Turns out the smoke I was seeing was just exhaust. It was looking thicker and smoke-like in the weather we've had here lately.
And I think I'm paranoid that the problems are always bigger on this rig.
Happy to know it's not a big ticket item.
Jst4fun
Oct 16, 2017 09:51 PM
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
