my new to me white 1999 D2
Old Mar 11, 2016 | 07:49 PM
  #41
BS50MGSXR's Avatar
Got this in after work. Pulled all the old threads out and drove this in with the ryobi 18v 1/2 impact carefully and kept cleaning the hole and the self tapping drain plug. Finally got it in and then added the crush washer and torqued it down to 18 ft pounds. The little screw is torqued to like 7 ft pounds. I'll probably add some blue lock tight to everything tomorrow. Iv got a quart of oil sitting in the pan now. Will check if the plugs leaked any oil in the morning.
Old Mar 15, 2016 | 08:00 PM
  #42
BS50MGSXR's Avatar
Ok, well at walmart and can't unlock the car. I was able to stick something into the door and pop the lock, but with the key in the ignition it won't start and the alarm just goes off for a bit. Can I pull the battery cables to reset the system? Can I drill out the driver side door to turn the lock?
Old Mar 15, 2016 | 10:22 PM
  #43
Best4x4's Avatar
Can you roll the window down? Do you have a remote? Normally if you operate the door lock from the outside to lock unlock it will reset the alarm. It saw the door open without a remote or key so it triggered the alarm/immobilizer. Either a lock/unlock via remote or door lock will reset it.
moorebl
Nov 10, 2013 09:00 AM
essco22
Feb 21, 2011 12:30 PM
psk8888
Aug 28, 2010 03:02 PM
95raingerowver
Feb 19, 2008 03:13 AM
wileyabbas
Jul 27, 2007 03:48 PM
