my stupid. tap tap tap from front end
Old Aug 25, 2019 | 12:27 PM
stefanas's Avatar
Default my stupid. tap tap tap from front end
Mistakes are my greatest teacher. I've upgraded tires 255-265, but stupid me only had time to do the fronts, and save the rears for the next day.
Drove home, weird skipping, chirping from the tires, then vibrating. DAMN its 4 Wheel drive you idiot. Drove back to the "Barns" where I work on it.
All tires are 265 now BUT . . .
I get this Tap Tap Tap from the front end when Im driving. It only happens when I let off the accelerator or if im braking. It doesnt happen when I am on the accelerator pedal.
Thoughts of where I should look? It drives great. no vibration, only that damn tapping. I knew I screwed something up.
Stefan
Old Aug 25, 2019 | 02:07 PM
FlyingZebra34's Avatar
Check differential fluid
Old Aug 26, 2019 | 02:17 PM
stefanas's Avatar
Ok this dont look good, looks like something (rubber boot) got chewed up. Anyone can shed some light on what this is and what I should know about replacing it?
Old Aug 26, 2019 | 02:30 PM
stefanas's Avatar
Default Drive Shaft Rubber Coupling?
Is this it? https://www.roverparts.com/Parts/TVF100010
Old Aug 26, 2019 | 02:40 PM
Ben Matheson's Avatar
no vibration he says LOL
rotoflex, replace it.. do not drive it until it's fixed
Old Aug 26, 2019 | 02:51 PM
stefanas's Avatar
Will do and thanks. Yet, no vibration, just taps and occasional clank. Thanks man!
Old Aug 26, 2019 | 02:55 PM
stefanas's Avatar
This is the correct part yes? https://www.roverparts.com/Parts/TVF100010
Old Aug 26, 2019 | 03:36 PM
Richard Gallant's Avatar
@stefanas Yup just pay attention to the arrows when you take it off it has to go on a specific way
Old Aug 26, 2019 | 06:06 PM
stefanas's Avatar
Thank you guys! Just ordered.
Old Aug 26, 2019 | 06:43 PM
Brandon318's Avatar
Replacement is easy too. No jacking required, as you probably could've guessed crawling under and taking a photo. Took me an honest 20 minutes to replace.
