My SUV sounds like A 1965 VW Beetle and seriously Under Power!!!!
Old Nov 16, 2006 | 12:24 PM
mr.47's Avatar
Default My SUV sounds like A 1965 VW Beetle and seriously Under Power!!!!
Hi
I got 1996 LR1, and the problem is it sound like a VW and the seems to dramaticly decreaced. The check engine light is on and i when and check with autozone, they check with the computer and said the problem is the air mass sensor, he told me to clean it with break cleaner. So Should i clean it or replace it?
Thx
Old Nov 16, 2006 | 02:13 PM
Default RE: My SUV sounds like A 1965 VW Beetle and seriously Under Power!!!!
Did this all happen at once or has it been building up over time.
Cleaning the MAF usually only works at best for a short while at best. If the MAF is bad, t will lower your power, cause shifting problems in 3rd or 4th gear and cause the exhaust to smell.
Before you do anything, go get someone else to read the codes again and get the fault numbers, lets make sure he even knows what he is talking about. Get back to us with that info and don't try cleaning the MAF to all other things are ruled out cause once you start messing with it, there is no turning back and at $600 or so, you don't want to be the cause.
Mike
Old Nov 19, 2006 | 12:28 AM
mr.47's Avatar
Hi
I took it to the dealership and they told me to replace it , i haven yet replace, and i did not know the MAF will decrease performance when it broken, and also what the MAF do anyways
Old Nov 24, 2006 | 07:08 PM
mr.47's Avatar
Hi
I decided to clean it with the brake cleaner and it got rid of the bad exhaust smell, the engine still sound the same but this time the engine shakes when i give it some gas and when at idle, so could that mean that the engine is missfiring again?, i replaced my spark plug about 6 months ago.
Thx
Old Nov 24, 2006 | 11:14 PM
Brake cleaner will kill the MAF, shop around for a good used one with a guarante, try
http://www.roverlandparts.com/index....TS&Category=63
Or you can buy a new one for $600 plus.
For others reading this, it is really hard to clean failing MAF and if you try use electrical contact clean not carb or brake cleaner.
Mike
Old Nov 25, 2006 | 01:30 AM
ArizonaDisco's Avatar
7th Gear
If your Disco has more than 75K miles chances are you have a stuck exhaust valve. Check the codes and do some research and you'll more than likely find this to be the case. It's usually the #8 valve.
MarkSF
Mar 3, 2014 11:43 AM
NZ_Hunter
Other
Sep 13, 2012 04:26 AM
savageracer2008
May 18, 2011 07:15 AM
Spencerfitch
Feb 7, 2011 04:59 AM
05lr3guy
Feb 1, 2011 08:54 AM
