My Tachometer just stopped working. Please Help
Old Nov 16, 2012 | 08:53 PM
Jason428sc's Avatar
Default My Tachometer just stopped working. Please Help
Hi Guys,
I've got a 2001 Disco and I fired it up a little while ago and the tachometer did not work. All the other gauges seem to be working fine. I drove it about 5 miles and it never started to work. Tapped on the dash and still nothing. Any ideas?
Thanks.
Old Nov 16, 2012 | 09:15 PM
You can use a $70 Ultra Gauge to display rpm, coolant temp, and other things. Driven by ECU thru OBDII port. ECU also drives tach signal in a D2. D1 gets that drive from alternator.
Old Nov 17, 2012 | 07:28 AM
Jason428sc's Avatar
If I switch out the ecu will I need to switch the instrument cluster too, so the milage will match? I do have parts vehicle with both.
Thanks
tsuyoi
Sep 22, 2020 10:37 AM
DiscoDad
Dec 19, 2010 03:01 PM
tornado_735
Jul 22, 2010 05:53 PM
crama12013
Apr 14, 2010 03:29 PM
mdoty
Jan 11, 2008 10:41 AM
