Is my transfer case really getting hot?
I know that you do have a lot of upgrades like new gears, TT lockers, bigger tires, HD drive shaft (not sure on that one but knowing you), and many more upgrades. Maybe it's as simple as your upgraded rig isn't up to rolling 80mph anymore. But like you, I am mostly an idiot
you maybe right. I have built the perfect parking lot security vehicle.
as you mentioned, I fear there is an issue with a diff. ...this weekend I will start the shaft drop and drive testing. oh, boy. I just made it home, at least. so, no I81230, yet.
on to the solution.....
Dusty,
Overfilling your transfer case or anything else is bad, i hear a lot of people doing it.
Most time if you overfill something with gears, they tend to cavitate and mix air into the oil. eventually you will end up making foam rather than pumping or splashing gear lube around.
JMHO
JMHO
