My transfer case will go from l to h but won't move
Old Aug 23, 2019 | 12:12 PM
agoyne's Avatar
6th Gear
Default My transfer case will go from l to h but won't move
While driving at a very slow sleep, the vehicle transmission starts slipping and grinding and then it won't go anywhere. It's making a grinding noise but will not move in REV or FWD. HELP
Old Aug 23, 2019 | 12:24 PM
Richard Gallant's Avatar
Ok that is not good can you confirm the transfer case is actually in gear.
Old Aug 23, 2019 | 02:25 PM
agoyne's Avatar
6th Gear
My my next step is check the hydraulic fluid.
Old Aug 23, 2019 | 02:43 PM
mollusc's Avatar
make sure you identify the particular system that is causing the problem. the transfer case (lo/hi) is separate from the transmission (r/n/d/etc) and each one has its own different fluid/oil.
Old Aug 23, 2019 | 06:53 PM
lordmorpheus's Avatar
Broken driveshaft? That would also cause it go nowhere.
mutant
Apr 11, 2017 05:16 PM
SWAINROVER
Dec 5, 2015 04:38 PM
georgep
Apr 16, 2012 08:52 PM
joefresso
Apr 25, 2011 07:18 PM
ajh
Oct 23, 2006 09:42 PM
