At my wits end
Old Oct 17, 2013 | 08:03 AM
dr. mordo's Avatar
You need to post your actual codes. It will help us diagnose your problem.
Old Oct 17, 2013 | 10:36 AM
clanch's Avatar
A plugged cat will cause misfires. The easy thing to due is unbolt to down pipe that the misfires are on. Bank 1 or 2 and drive it. If the power is back cat is plugged. Or screw a pressure gauge into the 02 sensor hole and measure the back pressure.
Old Oct 17, 2013 | 02:55 PM
rmcshaffry's Avatar
When we had symptoms like that we had sheared a rocker arm. Flashing MIL typically indicates "stop driving me now". YMMV.
r
Old Oct 17, 2013 | 06:18 PM
coors's Avatar
Double check all the spark plug boots are properly seated (coil and spark plug ends). Especially, cylinder number eight where you see the misfire code. I think cyl 8 is the last plug closest to the firewall on the passenger side.
Also, pull and inspect cyl 8 spark plug. Is it charred? Is the end terminal where the boot connects loose? Sometimes, if you inappropriately wiggle the boot it works the plug's terminal nut loose.
Old Oct 24, 2013 | 05:56 AM
jjrene1's Avatar
6th Gear
So I finally have had the time to pull the codes. Perplexing considering what I've done so far, but here goes:
P0300
P0308
P0306
P0307
P0301
P0305
P0303
Old Oct 31, 2013 | 02:38 PM
jjrene1's Avatar
6th Gear
Problem solved: I vacuumed the air intake and air filter housing and purchased a new MAF sensor and air filter. My baby is back!!! SEL is off and has not come back on.
Old Oct 31, 2013 | 09:20 PM
dr. mordo's Avatar
Good news!
Congrats
Old Nov 4, 2013 | 01:10 PM
jfall's Avatar
Nice job.
How many miles were on it?
Did you try to clean the old MAF?
I am trying to figure out what damaged it....
Old Nov 4, 2013 | 11:14 PM
bosshogt's Avatar
Also just to post this to your thread. Because my fix exhibited the same symptoms as your issue. Flashing SES light no power. Limp. For any future people trying to fix these symptoms. Check the passengers side O2 sensor electrical connector. Mine was corroded with green corrosion. Took the dumb dealer 30 days to never figure it out and tried to charge me $2500. Talked them down to $500 for poor service. Now I've fixed everthing myself since 2008. Rover On!
Old Nov 6, 2013 | 07:51 AM
jjrene1's Avatar
6th Gear
It has 113,000 miles. I did attempt cleaning out the old Bosch MAF, but that proved unsuccessful.
mrossipir
Nov 8, 2010 08:02 AM
NM-DiscoDuck
Oct 9, 2009 08:13 PM
alanroberts50
Aug 21, 2009 07:20 PM
amryav8tr001
Oct 16, 2007 12:42 PM
Doss
Jun 4, 2007 04:39 PM
