At my wits end with Fuel Pump
Old May 29, 2007 | 03:37 PM
Doss's Avatar
Default At my wits end with Fuel Pump
I have been working on getting fuel to my 97 Disco off and on for 6 weeks.
I cannot understand what is happening.
When the switch is turned on, I have 11.6 volts at the plug going into the fuel sender assembley and at the plug that goes into the actual pump itself.
However, the pump won't turn.
I can unhook the pump from the plug, connect leads to the pins, touch them to a battery and it turns.
There is no rational explanatation.
I think I am down to getting it to a mechanic, I can't understand why it won't work.
Old May 29, 2007 | 06:37 PM
rinmud's Avatar
Default RE: At my wits end with Fuel Pump
fuel pump relay cooked look for the used to be yellow but now brown relay in engine compartment box
Old May 30, 2007 | 07:17 AM
Doss's Avatar
have you seen this before?
Old Jun 4, 2007 | 04:39 PM
hoberock's Avatar
Could be the relay or the reset switch. You can cycle the reset switch to see if this helps. My '96 had an issue of working fine when given 12V from the Battery, but during driving operation would crap out some times. Replacing the pump resolved the issue...
Tim
mrossipir
Nov 8, 2010 08:02 AM
demonlarry
Jul 10, 2010 10:20 AM
NM-DiscoDuck
Oct 9, 2009 08:13 PM
alanroberts50
Aug 21, 2009 07:20 PM
amryav8tr001
Oct 16, 2007 12:42 PM
