Mystery oil leak. HELP!
Old 03-14-2017, 05:33 PM
chockster's Avatar
Default Mystery oil leak. HELP!
Hi all.
I posted on here a little while ago but still trying to find the answer or someone with the same problem.
It an 03 Disco 2 4.6L v8 hunk o ****e. FYI
I have an an oil leak coming from behind the engine mounts on both sides of the engine.
Before you say it, no it's not the rocker covers or valley seal. I de-greased the engine and then ran it. The top is completely dry. But when I crawled underneath there is a steady seep coming from right where the motor mounts are on both sides.
Without removing these here I cannot pinpoint the location. So my question is this.
do the motor mounts bolt through the block lending itself to a potential leaking point? The bloke who had the car before me had them replaced they are brand new.
On the passenger side I found a 10mm square headed sort of grub screw bolt which I wound in (conveniently the same size as a half inch drive)
But no luck.
I don't mind a bit of a leak on a landy but this is too much. People in the car park keep asking me if I'm aware of the leak and to get strait to a garage. Never been to one in me life apart from MOT or smog 😁
Any info appreciated.
also Ive put a picture on of the leak.
Old 03-14-2017, 06:06 PM
Red5's Avatar
This bolt is the issue. Pretty sure those aren't factory, looks like a fix for a slipped liner. Remove, RTV, replace.
Old 03-14-2017, 06:41 PM
BackInA88's Avatar
Remove, CLEAN, RTV, replace
Old 03-14-2017, 06:47 PM
chockster's Avatar
Hi Red5. Yea your right. Its a slipped liner and its pinned. Although that is leaking a little it doesn't seem to the issue i am chasing. Unless there are more behind the mount?
I might just pop the mount off and have a look behind. Is it fairly easy once the engine is supported?
Old 03-14-2017, 07:30 PM
chockster's Avatar
P.S - whats RTV?
Old 03-14-2017, 07:59 PM
Red5's Avatar
Old 03-14-2017, 08:18 PM
chockster's Avatar
Good shout thanks mate.
Old 03-14-2017, 08:51 PM
OverRover's Avatar
Here is the info from RAVE (LR Manual) you will need to remove the mounts.
chockster (03-14-2017)
Old 03-14-2017, 08:54 PM
chockster's Avatar
So I take it the bolts are not connected through to the sump?
Old 03-14-2017, 09:42 PM
OverRover's Avatar
Correct, the motor mount plate is bolted to the engine block. The oil pan/sump is below.
Quick Reply: Mystery oil leak. HELP!
