Name that noise!
Old Oct 23, 2016 | 08:55 AM
Racer X's Avatar
Default Name that noise!
I'm almost certain that it's the 80mm pulley under the PS pump, and not the PS pump itself, but I thought I'd get the opinion of the commentariat first.
It's only been happening as the weather has gotten colder, and will eventually cease as the engine comes up to temperature.
Old Oct 23, 2016 | 01:27 PM
OffroadFrance's Avatar
A cat trapped on the engine
Seriously, it sounds like a belt rubbing or maybe a dry bearing.
Old Oct 23, 2016 | 05:58 PM
Racer X's Avatar
I live in Queens, NYC. You always tap your fenders before starting the engine.
That's a mess I never want to have to clean up again.
Old Oct 23, 2016 | 07:24 PM
number9's Avatar
Easiest way to confirm or dismiss a pulley/idler bearing noise is to remove belt and rotate each by hand and feel/listen for signs of failure. Alt. and H2O pump can also be rotated to check.
Old May 6, 2017 | 09:46 AM
Racer X's Avatar
It was a dry bearing.
Old May 7, 2017 | 05:11 AM
TIP: To eliminate whether it's a belt slipping or not fill a garden type hand sprayer with water or even washing up liquid at 100:1 and spray the belts with it in an organised order, say from left to right, and if the noise disappears it's usually a belt. (never use an oil based fluid like WD40 as the belts will continue to slip more even when tight)
jwigum
Aug 13, 2016 07:59 PM
parkerlander
May 20, 2014 08:37 PM
Disco.Jay
Feb 24, 2006 05:32 AM
Patrick
Off Topic
Apr 5, 2005 09:14 PM
