narrowband or wideband O2 sensor
Old Jul 23, 2008 | 06:13 PM
alemurill's Avatar
Default narrowband or wideband O2 sensor
Hi,
How do I find out if my Disco has a narrowband or wideband O2 sensor?
As I understand narrowband are the most commond ones.
All the 4 sensors (2 pre/cat, 2 post/cat) have four wires.
Discovery 96 SE7 (4L, V8)
Thanks,
Old Jul 23, 2008 | 09:22 PM
Default RE: narrowband or wideband O2 sensor
You are overthinking it.
http://www.roverparts.com/Parts/ERR1834.cfm
http://www.roverparts.com/TechTips/k...ons_system.cfm
Old Jul 23, 2008 | 09:43 PM
Darover's Avatar
I agree with Spike...Why ask ??? There are fairly cheapapplications for your Discovery so why bother trying to match any other ones. Unless you study in this field and was just wondering.
Old Jul 29, 2008 | 07:32 PM
alemurill's Avatar
it's Titania
Old Jul 29, 2008 | 08:00 PM
ORIGINAL: alemurill
it's Titania
Whats that?
Old Jul 30, 2008 | 09:18 AM
It is based on your vin. Go to Rover Connection and use their guide line to find the proper 02 sensoer for your truck.
Old Jul 30, 2008 | 01:45 PM
alemurill's Avatar
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 Style Definitions table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Zirconia O2 sensor (narrowband/wideband) Creates an output voltage corresponding to the quantity of oxygen in the exhaust relative to that in the atmosphere.
Titania O2 sensor Does not generate its own voltage, but changes its electrical resistance (ohm) in response to the oxygen concentration. Titania O2 Sensor Cable designation: red - 12 V (heater) white - 10.8 V return (heater) 1.2 volt stay always inside the sensor yellow ground black - sends resistance (ohm) signal to the ECU
Old Jul 30, 2008 | 01:47 PM
alemurill's Avatar
red
- 12 V (heater)
yellow
ground
black
Old Jul 30, 2008 | 03:19 PM
Darover's Avatar
[8D]Dude???[8D]
That's quite a bit more technical than I can handle, but thanks for the new knowledge.
Old Jul 30, 2008 | 05:22 PM
LR uses heated O2 sensors. Thats all you had to ask. Heated or not.
KlamathMatt
Apr 17, 2020 05:27 AM
jfoley1
Mar 18, 2009 06:52 PM
stupid
Nov 23, 2008 01:17 PM
jmccollister
Sep 9, 2008 08:50 PM
Morgan
Aug 14, 2007 08:15 PM
