Near constant drivetrain whine now...
Old May 28, 2010 | 06:09 PM
starrock's Avatar
Default Near constant drivetrain whine now...
I posted a couple of weeks ago about a whine in my drivetrain during acceleration / maintaining speed at ~75mph. Made the 700 miles from Nashville to Tampa no problem but the couple hundred miles down here has now led to a near-constant whine that now increases in volume at ~38mph and again at 75. I've changed all diff/transfer case/transmission fluids and greased both driveshafts. Still there.
Return trip is tomorrow. Don't wanna be stranded since I have my 3 year old with me. Wish me luck! Ideas on sound? I should mention that I incorporated the spare tire into the rotation about a month ago and it has about 3/16 inch more tread than the others. There was no pulling to either side so I left it. Did it cause the whining? I can't recall if it was there beforehand or not...
Brian
Old May 28, 2010 | 06:32 PM
Put the other tire back on.
Rotating the spare which is bigger around than the other tires will put extra strain on the driveline.
You can do it for a short amount of time but not for a long trip, thats why its called a "spare tire"
Old May 28, 2010 | 06:45 PM
hilltoppersx's Avatar
did you rebuild or replace your driveshaft since you bought the truck?
Old May 28, 2010 | 07:23 PM
bmw zhp's Avatar
he has a toddco front shaft.
Old May 28, 2010 | 08:50 PM
starrock's Avatar
Yeah Spike first thing I did when I got here was put spare back. We'll see how it goes...hate that I possibly (probably?) caused it. Oh well...
Old May 29, 2010 | 06:10 AM
didnt read that in the sig.
have you greased the u joints AND the centering ball reguarly?
Old May 29, 2010 | 09:41 AM
Did you lube the new drive shaft before installing it, have you checked and or changed the fluids in the t/case and diffs?
Old May 29, 2010 | 10:17 PM
bmw zhp's Avatar
honstly not trying to be a jerk but you should read the post before posting
Old May 30, 2010 | 08:07 AM
starrock's Avatar
made it without issue...phew! No increase in noise afterward either. Would Lucas oil stabilizer do as it claims and decrease whine in transfer case / diffs? or should I just continue as-is until it decides to worsen and thus allow me to determine the noise's origin?
Overall I'm impressed with the vehicle's performance...1600+ miles over the week, zero failures, 16.6MPG with AC on 85% of the time. Burned no oil. Eh, pretty uneventful overall. No exciting tales to tell.
Thanks for the responses...Brian
Old May 30, 2010 | 08:28 AM
No, it won't help. You need to get the truck up on a ramp and have a mechanic listen to both diffs. , t/case and tranny and see which is trying to die on you.
