Necessary to replace the oil drain plug washer?
Hey all!
First oil change on the new Disco and, coming from the BMW world where new drain plug washers must be used every oil change, I'm wondering if its the same with the D2. I haven't found any mention of it reading through the forums, but I see that Atlantic British includes one with their oil change kit. Although, they also include a new drain plug and I doubt that's always necessary...
Mine is not a crush washer and the one sold by AB also is not, just a steel washer.
They sell more than one, but this is the one I had on mine and still do with no leaking.
Its not a crush washer.
https://www.roverparts.com/Parts/ALU1403L
The crush washers for the V8 are so cheap I just replace them.
You can get the Honda #94109-14000 crush washer for cheap and has the same dimension as @OverRover stated above.
