Need advice
try walmart.com. Rotella is usually sub 16 a gallon. Used to be sub 14 a gallon. Orders over 35ish ship free. I have get a commercial discount from the local automotive chain stores and Walmart off the shelf Rotella is usually cheaper. Same with their ac coolant cans.
My passat diesel takes a gallon at each change. My boat and excursion diesels take nearly 5.
https://www.walmart.com/ip/Shell-Rot...-Oil/181236405
I just changed the oil in my excursion 2 weeks ago
this is 13 and change per gallon. Less than 4 bucks a qt.
I'm glad i have an extra 5 gallons. I have a feeling between the fuel cost hikes and mass workers strike an already weak work force is being further depleted. Mobile 15w40 gallons synthetic blend looks to be in stock. Im not sure I'd use it in my 7.3 but I'd run it in the rover as well as my vm 4.2 marine turbo diesel.
