need advice on aligning crank sensor
Old May 15, 2013 | 10:50 PM
FreeRideSLR's Avatar
Have a friend hold the wire from the top as you work from the bottom. I spent an hour trying to reconnect it myself. When I got someone to help it took all of 2 minutes.
Old May 20, 2013 | 11:29 PM
kdscott100's Avatar
Thank you for your advice, and it was indeed, two minutes. I am uncertain whether I would remove the exhaust for the next go round, as dis-assembly was easy. Also, after researching this topic I had no idea the CPS was so problematic; in fact, I wonder if it should go on the list for high mileage Rovers? Thanks again for your assistance.
Old May 21, 2013 | 10:00 AM
No problem. I'll probably remove the exhaust if this ever happens again. I also bought a spare to keep in the truck after mine died in the middle of a trail.
Old May 21, 2013 | 10:31 AM
kdscott100's Avatar
Exactly my thought. There are many things that can go wrong with a Disco, but in most cases, you can repair on the spot and limp home, but when the darn engine will not start....We typically go where there is no cell phone coverage, so I too, will be buying a spare......
Charlie_V
Aug 20, 2015 09:17 PM
TRIARII
Oct 29, 2012 01:01 AM
cgeschwell
Feb 23, 2011 01:01 PM
dustinvonholten
Nov 23, 2010 05:08 PM
stupid
Nov 23, 2008 01:17 PM
