Need advice on Replacing the Starter Inhibitor
Old Oct 28, 2008 | 03:56 PM
tex599's Avatar
Default Need advice on Replacing the Starter Inhibitor
I have a 2003 disco, the M&S light were flashing and it threw a trouble code p0705. According to Rave and others on this board it is the Switch Gear Position Indicator or Starter Inhibitor that is bad. I have already replaced the battery, so it is not low voltage and anytime you shift really quick into reverse or drive it will throw on the M&S lights. So my guess is it is corroded from water or the contacts on the inside are bad.SO my question is, looking at Rave it shows you need a special tool LRT-44-011 to align the selctor shaft and the new switch has anybody done this without the tool. Any advice.
Thanks,
Tex
Old Oct 28, 2008 | 04:10 PM
Default RE: Need advice on Replacing the Starter Inhibitor
I bet Tacomatech knows this one. He is a Rover mechanic.
Old Oct 29, 2008 | 08:36 AM
tex599's Avatar
bump, anyone
parksy
Feb 8, 2021 06:39 PM
mjbrox
Dec 10, 2014 09:35 PM
CapeCod98Disco1
May 4, 2012 11:40 AM
dlacar88
Nov 23, 2010 08:31 AM
dlacar88
Nov 22, 2010 04:43 PM
