Need exhaust ideas
Old Jan 19, 2017 | 12:34 PM
Joe!'s Avatar
Originally Posted by Best4x4
I like a Magnaflow 11226 muffler and removing the resonator. It sounds very nice, with a great exhaust note. It's a V8 when you step on it, but when you're cruising around thru town it's pretty darn quiet.
I have that setup on all of my D1/D2's.
Is that Magnaflow 11226 a direct fit?
Old Jan 20, 2017 | 12:21 AM
OffroadFrance's Avatar
Originally Posted by Alex_M
I've had something like 7 different setups on my Rover almost all including magnaflow cats which are somewhat different tone and louder than stock cats. They have included single perforated glasspacks, dual louvered glasspacks, single 9" louvered glasspack, regular old resonator delete, straight pipe, etc.
Let me tell you, first and foremost, do NOT go flowmaster. The drone is worse than with straight pipes. I had the flowmaster 40 specifically, but even coupled with a resonator it was still colossal.
The single perforated core glasspack wasn't bad, but wasn't great. Drone wasn't terrible though.
By far my favorite has been my Borla Pro XS. It began with magnaflow cats and the single in dual out muffler which I have a clip of somewhere. I'll see if I can find it. The drone wasn't bad at all and had a nice rich tone. It has since morphed to long tube headers, no cats, 2.5" y-pipe, into the Borla, then 3" single out the back with not one, not two, but three resonators. Going catless makes this truck LOUD. That said, even without any of the resonators there was absolutely zero drone after I went to long tube headers.
Anyway, my final recommendation is the Borla Pro XS. I definitely recommend it going on out the back. That will further decrease cabin noise as opposed to a dump. Should be a simple cut out and weld in procedure for both the muffler and the resonator and you'll only need a couple lengths of 2.5" pipe which the exhaust shop will have in stock if you take it to a shop.
Edit: Here is the old video I had. The sound isn't great as it was recorded on a knock off go-pro, but still gives you somewhat of an idea.
https://www.youtube.com/watch?v=SAoGAhVJFh0
I don't know about the exhaust Alex but I reckon your Watts linkage bushes are shot that or the shocker bushes. (I like quiet trucks, no noise, no roar, just sedate )
Old Jan 20, 2017 | 09:32 AM
Clay Stanley's Avatar
I used these headers.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
They say they're for a RHD Range Rover Classic, but they were a perfect fit. Install them from the top with secondary air removed. It will still fit back after no problem. I would definitely have them ceramic coated also because they are pretty thin and rust pretty quickly.
I will say, if I could change one thing, it would be to replace the header ball and cup adapter with 2.5" v-band clamps. If I could change one other thing, I'd use catalytic converters. Probably a spun style. You don't see any gains from losing the cats, but in the US it's a $10,000 federal fine if you're caught without which can be administered from both a visual check and a smell check.
As for the resonator, when I had my stock setup I ran without. That said, the single in dual out muffler is a little longer than the single in single out, so it may be a hair louder than the single/dual and therefore you may prefer a resonator though I doubt it would be terribly loud without. I would probably run without the resonator, but that's just my personal preference. If you have the ability, I would try it without first and if you think it's a little loud then add one before you have it coated since that minute detail really comes down to personal preference.
got any pics of these installed?
Old Jan 20, 2017 | 11:27 AM
toofaroffroad's Avatar
Default Flowmaster 50 series sound
Hi link below to more details and sound clip.
https://www.youtube.com/watch?v=hbA0OnlvoEw
Old Jan 20, 2017 | 08:03 PM
Luckyjayb's Avatar
https://landroverforums.com/forum/headers-intake-exhaust-12/land-rover-discovery-2-without-y-pipe-81515/#post592666
sounds pretty good. Not too loud but you can still tell it's a v8
Old Jan 23, 2017 | 11:31 PM
phatduc's Avatar
Anyone tried a magnaflow 11256, which the same 4x9" oval of the 11226, but 18" long instead of 14" length? I'm running magnaflow Y pipe +cats and want zero drone or raspiness, straight-thru, but only a little louder than stock. The borla and magnaflow 11226 sounds a little raspy for my taste, so i'm wondering if the extra 4" of length of the magnaflow 11256 might take care of that along with the resonator.
Old Jan 24, 2017 | 09:05 AM
Alex_M's Avatar
Haha, I forgot about the rattling. That's actually the camera vibrating against the rear window.
Old Jan 24, 2017 | 09:06 AM
Alex_M's Avatar
I believe I do if you follow the link in my signature. Ill double check after class.
tigertrakstar1
Mar 5, 2014 04:13 PM
twaszak
Jul 15, 2012 07:21 PM
Street Wolf
Jun 24, 2011 01:59 AM
Disco-Nate
Sep 17, 2009 07:39 AM
kkisting
May 5, 2008 01:12 PM
