need help fast
Old Jun 3, 2009 | 04:08 PM
adamsdisco2's Avatar
8th Gear
Default need help fast
wats up guys i had to replace the crank position sensor in my 03 discovery and now it just cranks and wont start at all. do i have to get something reset, can it be done by the free code reader at autozone or not
Old Jun 3, 2009 | 04:16 PM
ryanD2's Avatar
pull the negative lead off the batt for a few mins, not the rite thing to do but it should reset if you're in a bind.
Old Jun 3, 2009 | 06:24 PM
The crank sensor is plug and play, no reset needed.
But like ryand2 said give it a try and let us know how you make out.
Old Jun 3, 2009 | 06:27 PM
8th Gear
no go still just cranks no codes with the obd 2 reader dont know what to do thanks for the help
Old Jun 3, 2009 | 07:28 PM
Check for spark, report back.
Old Jun 3, 2009 | 07:33 PM
8th Gear
i checked for spark in #2 and did not see nothing
Old Jun 3, 2009 | 07:37 PM
Ok, it is either the cranks sensor or the coil pack, check for spark on the other side of the engine.
Old Jun 3, 2009 | 08:43 PM
8th Gear
the problem i had before i replaced the crank sensor would probally help you guys a little better. i stopped at a gas station 4 days ago and it would not start the battery ran dead so i got a jump and it fired right up so i got it home and it started 4 times in a row. so i drove it to work the next morning and shut it off and came back out 10 mins later and it wouldnt start so i looked for spark in #2 and found nothing.so i checked all the fuses and and thought it was the battery so i replaced it. then i was on my way home and it stalled in the middle of the road and would not start up so 15 mins later it fired up and got it home and then it would not start so i replaced the crank sensor today and it just cranks with the old one it would lest start up im lost on what to do.
Old Jun 3, 2009 | 09:07 PM
Did you get the correct crank sensor?
Did you install it correctly?
Put the old one back in and see if it then starts and runs.
Old Jun 3, 2009 | 09:14 PM
8th Gear
do you know where the spacer go i have them between the sensor and the metal part that comes on the sensor i tried it in front of it but still didnt work ill try to put the old one back on tommorrow. also the part # matched on both sensors.
