NEED HELP- front cover removal
Thanks for the replies. On the 5th or 6th time holding the gasket up I found the bolt I had been missing. Did replace the oil pump gears and have the timing chain and gears to do. Also did the valve cover gaskets while in there and do an inline thermo conversion. Turns out that was all too much for one day interrupted by a thunderstorm. Sometimes I get a bit too optimistic. Thanks again guys, preciate it.
The one that sits just below the little tab that the connector sits on? Can't tell you how many times I looked the whole thing over! Then it was that a-ha moment, followed by the grumble about wasting hours...
" What's this about oil pickup tube o-ring? I don't recall seeing one when pulling the pan? Which part of the tube does it go on? "
ERR4794, it's number 10 in the pic> Discovery II, Engine, Sump - Rovers North - Classic Land Rover Parts
Again, huge thanks guys. Did not notice the pick up oring during teardown. Had a look and verified there's one on there, nice and snug. A shout out to Justin at L8 for his help with that. Got the timing chain and gears, along with the front cover on last night. Tonight it's the water pump, oil pan and inline mod. This whole work thing during the day just kills my free time...
tshirttom
10-22-2014 10:03 AM
lipadj46
11-15-2009 05:59 AM
a1machinista1
09-29-2009 10:51 AM
