Need HELP! Intermittent crank no start
Hello
I have a 2004 Discovery 2s. Drove into driveway a few days ago and car stalled. Cranked over but would not start. I checked the fuel pump relay,relay OK. I put starter fluid in intake and vehicle tried to start. So, I figured bad fuel pump. Next morning, started right up, but stalls out after about 20 minutes.
I replaced fuel pump $325.00 still same problem, after about 20 minutes dies and wont start. Let sit overnight, runs for awhile then dies again. No fuel filter to service from what I heard.
Any suggestions?
Any suggestions?
You need a new crank position sensor.
$70 part, should have asked first.
Looking at the engine, 3o'clock position on the bell housing.
You can buy it at AutoZone, exact same part just in a different box.
http://www.roverparts.com/Parts/ERR7354G.cfm
Had this done on a road trip...
My CPS failed on the way to the beach, and the mechanics at a Goodyear dealership hooked me up for about $150 parts and labor (as I recall) and I was back on the road in 2 hours. Probably would have taken me 3 hours at home, with my luck and mechanical prowess... CPS is a good preventive maintenance item in my book.
DRW
DRW
