Need help with a leak, brake fluid?
Old Jan 7, 2016 | 11:27 AM
adamwest21's Avatar
Default Need help with a leak, brake fluid?
Hi guys, I was gone for a week and came home to the Disco having a wet spot underneath and near driver side wheel. Ill attach pics. The leak seems to be from the master or booster. Im super tight with money right now and its gonna have to wait but Id like to know you guys opinions on what it might be and where to look. Fluid is not down in reservoir.
2000 Discover II .Thanks!
Attached Thumbnails Need help with a leak, brake fluid?-img_20160107_102758017_hdr.jpg   Need help with a leak, brake fluid?-img_20160107_103007020.jpg   Need help with a leak, brake fluid?-img_20160107_103000075-1-.jpg
Old Jan 7, 2016 | 11:31 AM
drowssap's Avatar
you need a new master it leaking out the rear seal, if left long enough the brake fluid can effect the rubber bladder in the booster
Old Jan 7, 2016 | 11:42 AM
number9's Avatar
Default Temp Repair
Difficult to call by photos, my leaky reservoir seals left same evidence at rear seal.
What did you do with your DII today? - Page 305 - Land Rover Forums - Land Rover Enthusiast Forum
You need to get off your wallet and fix the forking brakes before you kill somebody besides yourself.
Old Jan 7, 2016 | 01:06 PM
DiscoCam's Avatar
That seems to be the seals at the bottom of the reservoir. I had the same problem a few months back. Easy fix. You just need new seals.
Old Jan 7, 2016 | 01:23 PM
adamwest21's Avatar
Do you all suggest the seal kit for $99 from Atlantic British?
Old Jan 7, 2016 | 02:11 PM
abran's Avatar
If you are tight on money, Lucky8 is way cheaper.
Send an email to Erik,
Erik@lucky8llc.com
They have better prices than AB everyday of the week.
Old Jan 7, 2016 | 08:52 PM
DiscoCam's Avatar
Lucky8 is a good choice. There is also one on Amazon for $70.
Old Jan 29, 2016 | 10:50 AM
adamwest21's Avatar
Thanks guys, contacted Erik at Lucky8 and got the rebuild kit, problem solved!!
Rover Chris
Oct 12, 2015 06:03 PM
bantham1
Nov 8, 2010 03:55 PM
tubadude
Jan 12, 2009 09:36 PM
rgrizzard
Mar 6, 2008 10:16 AM
starcraft
Oct 16, 2007 06:02 PM
