Need Help - Nanocom Key Fob Programming - Key Not Detected
Old Jan 18, 2020 | 09:26 AM
cvhyatt's Avatar
Default Need Help - Nanocom Key Fob Programming - Key Not Detected
Hey All
I finally got a set of 315mhz key fobs and rented the Nanocom from @Brandon318 . I am following this video tutorial.
Everything seems to be going fine until I do the last step (key detect). The new key is not detected. A couple of other details:
  1. I have verified the nanocom receives a transmit from the new key
  2. My old key fob is detected just fine.
  3. It doesn't seem to matter which key programming slot I use - none are detected in the final step.
Anyone have any words of advice on what I can do here?
Old Jan 18, 2020 | 10:59 AM
Best4x4's Avatar
Just for kicks have you totally disconnected the Nanocom and tried the key? Fobs will not lock/unlock the car while you have the Nanocom connected (or at least my version of firmware will not allow this).
Old Jan 18, 2020 | 11:26 AM
Brandon318's Avatar
This.
Also, sometimes it took cycling through the key programming procedure one or two times. Some keys synced up right away, others took 2-3 times. No idea why the difference. Could be battery levels.
Old Jan 18, 2020 | 11:45 AM
cvhyatt's Avatar
Thanks guys. I tried the keys just to see if they were working but no joy. I will try programming a couple more times and see if it works. Will let you know.
Old Jan 18, 2020 | 12:50 PM
cvhyatt's Avatar
Well I tried replacing the batteries but still ending up with the same issue. Key sync is successful but key detection is not. I stumped.
Old Jan 18, 2020 | 12:58 PM
cvhyatt's Avatar
I'm thinking I got ripped off and they sent me another 433mhz. The motherboard looks the same as the last ones I got.
Old Jan 18, 2020 | 01:21 PM
Best4x4's Avatar
That could very well be, lots of people are running into that issue. I tried to program some with my Nanocom when I was up at Austin Roverworks as their T4 wouldn't do anything. Well they were a pair of those Mini Cooper remotes, and in the end they were the wrong MHz. Then a customer had an OEM key and the T4 didn't make it work. I grabbed the Nanocom and had it programmed in just a few seconds. I've programmed a few of the aftermarket units below with no issues.
315MHz Key Fob
Old Jan 18, 2020 | 03:19 PM
Discorama's Avatar
Do you have a HAM radio or a friend with a HAM radio? Easy to find out if the fobs are 315 or 433 MHz.
Old Jan 18, 2020 | 03:55 PM
cvhyatt's Avatar
That’s a good idea. Wish i did have something like that behind. In any case I am done trying to program key fobs for now. Going to replace my front calipers, bleed the brakes and send the Nanocom back. Thanks all!
Old Aug 27, 2020 | 01:46 PM
ReconDoc83's Avatar
315MHz Key Fob
Best; you have used this specific supplier? And this specific chip? Did it come with the 6 digit code or just the long code? Or both?
doc
