Need HELP PLEASE, will this tire fit this rim?
I need tires right away and I want to get them from Treadwright. This is the info for the Crawler in 235/85R16 Will this exact tire fit land rover 16" x 8" rims?
Thank you for any help!!
Tread Depth:18/32”
Tread Width:7”
Max Load:3,042 lbs
Max PSI:80 psi
Meas. Rim Width:7”
Rim Width Range:6.5-7.5”
Outer Diameter:32
Section Width:9.2”
Tread Depth:18/32”
Tread Width:7”
Max Load:3,042 lbs
Max PSI:80 psi
Meas. Rim Width:7”
Outer Diameter:32
Section Width:9.2”
