Need HELP PLEASE, will this tire fit this rim?
Old Mar 28, 2013 | 06:53 AM
cavdiver2's Avatar
Default Need HELP PLEASE, will this tire fit this rim?
I need tires right away and I want to get them from Treadwright. This is the info for the Crawler in 235/85R16 Will this exact tire fit land rover 16" x 8" rims?
Thank you for any help!!
Tread Depth:18/32”
Tread Width:7”
Max Load:3,042 lbs
Max PSI:80 psi
Meas. Rim Width:7”
Rim Width Range:6.5-7.5”
Outer Diameter:32
Section Width:9.2”
Old Mar 28, 2013 | 07:44 AM
taylor15's Avatar
I would go with a wider tire, or get a 7" rim
Old Mar 28, 2013 | 09:33 AM
You will get bad tire wear running on a 8" wheel, why not go to a 265, got a lot better selection of tread design and still pretty much the same size tire, just a little wider.
cavdiver2
Mar 12, 2013 12:35 PM
PLOWER99
Oct 3, 2012 05:02 PM
0304Disco
Aug 16, 2012 09:15 AM
apcollin
Tires
29
May 24, 2009 02:03 PM
spiderfreak80
Mar 22, 2006 10:52 AM
