Need help!! Who knows codes?
Old Feb 18, 2011 | 08:13 PM
cgeschwell's Avatar
7th Gear
Default Need help!! Who knows codes?
Ok, My '99 disco II is running ruff, I took it into my local shop (Not LR shop, just the local guy) he ran the codes and they are P 1300 P0300 (random misfire) P03(4)(7)0 not sure which and P1562 The problem is the car sputters during excelleration and idles ruff...any thoughts?
Old Feb 19, 2011 | 07:33 AM
Fireman's Avatar
P1562 - Battery supply below 9V while engine running - Maintains current gear in low range, limp home mode in range. Shift pressure to maximum, harsh gear shifts/engagement.
P0340 - Camshaft position sensor circuit malfunction
I could not find anything referencing P0370.
First, take you truck to Autozone or somewhere similar and have them check the battery. Once that is done, if you haven't already, consider replacing the CKP, wires and plugs.
Old Feb 19, 2011 | 07:02 PM
cgeschwell's Avatar
7th Gear
Thanks Fireman, I'm gonna work on it and try it all tomorrow, I'm gonna charge the battery over night and replace the knowck sensor, I should probably replace the plugs while I'm also ...shouldn't I.
Old Feb 21, 2011 | 05:22 AM
Fireman's Avatar
Yeah, both the plugs and the wires, but the knock sensor is probably not the problem.
cisney
Mar 5, 2012 09:06 AM
Lyagushkka
Sep 7, 2009 10:57 AM
zak
Jan 19, 2008 03:00 PM
CronicJoeBlunt
May 19, 2006 02:21 PM
