Need help with Windshield - Carolinas
Ladies and gentlemen, it happened. A semi send a rock my way and now I got a crack in the windshield. Would love to replace it with a genuine OEM glass - seems I can source it from the forum sponsor. Question: which should should I trust? Any tips will help.
I plan to do all the prep work and strip the plastics before bringing the car to the shop.
Cheers, --mc
Cheers, --mc
When you say "OEM" glass, are you referring to the tinted Pilkinton glass?
Safelite used Pilkington glass here in Charlotte when they replaced the windshield in my truck 10-12 years ago. As for heated versus unheated, I think insurance replaces with a heated windshield if that's what it had before. I toyed with seeing how much it would cost to upgrade to the heated windshield, but ended up not bothering because, after all, I live in Charlotte!
I didn't do any "pre-work", and it turned out fine, but I appreciate you wanting to take precautions and avoid the hassle of having to deal with getting anyone to replace the A-pillar trim, etc. On the other hand, if they break anything, they're on the hook to fix it whereas if you break it you're on your own!
Cost is not an issue. My biggest concern is finding qualified help. What parts do I need to get? Presume a windscreen and a weatherstrip. Anything else?
I recommend not removing the plastic yourself. You're also highly liable to break it, but if the installer breaks it the company buys you new plastic.
Safelite is a big company. Most of their technicians are qualified, but if there's an issue the company is big enough that they'll take care of it.
Alex is expanding on the point I made. You're likely better off to just let Safelite do the job, beginning to end. If something gets broken it's on them to fix it. And, you don't need to buy anything in advance. Safelite will supply what's needed.
There are a lot of Chinese windshields out there... Both heated and non heated... They don't last as long... a few years of highway travel and all you see is micro pitting. I wish State Farm would pay for Pilkington glass... I got them to use it when I had a rear door glass broken due to a car prowl when I noticed the tint was a different color and Safelite did replace it with one that matched which turns out was Pilkington. Never had that happen with the heated windscreen though and I've been through four or five now.
